VPN client without authentication
Jun 4th, 2008
Is it possible for Cisco vpn client on Windows to establish connection with PIX 7.2 without further authentication other than the Group Authentication. What I mean is there's no need for username/password. If yes appreciate if you can help with a sample config on PIX based on 7.2 s/w. ...txs RGC
Farrukh Haroon Wed, 06/04/2008 - 12:46
You can use this command to disable X-Auth:
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/i3.html#wp1799159
You can use the following document as a refence, just remove the 'xauth' part from it, that is add the above command in the Remote Access tunnel group (default is Xauth Enabled):
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008060f25c.shtml
Farrukh
khaledmansour Thu, 06/05/2008 - 06:37
Oh yes, that worked! Farrukh, thanks a lot for your help. greatly appreciate it.
brgds,
RGC
