IOS upgrade
Answered Question
Jun 4th, 2008
I need to upgrade the IOS on my 4506, sup 4. It is currently running 12.2.18-EW3 (DF). I'd like to get a lot newer IOS on there. But i'm stuck on deciding which one to upgrade. 12.2.44-SG (ED)is the newest one i can find. What is the difference between the EW and SG?
Correct Answer by Edison Ortiz about 8 years 10 months ago
argh,
try this one:
delete bootflash:cat4500-ipbase-mz.122-40.SG.bin
Overall Rating: 5 (2 ratings)
Edison Ortiz Wed, 06/04/2008 - 12:39
  • Hall of Fame,
    Founding Member
SG supporst NSF, WCCP and CoPP. I recommend going with it as it's the new line of code for the 4500 Switches.
12.2(44)SG or 12.2.(40)SG are solid choices.
HTH,
__
Edison.
cowetacoit Wed, 06/04/2008 - 12:42
The IOS i'm running now is very old, DF! So i won't have any problems upgrading to such a new IOS? There is about 20 IOS releases between the current and the newest. That bothers me. I'm just a cautious person.....
Edison Ortiz Wed, 06/04/2008 - 12:48
  • Hall of Fame,
    Founding Member
You should be fine.
glen.grant Wed, 06/04/2008 - 15:47
  • Purple, 4500 points or more
In the earlier days you did have to worry about new releases but these days code is a lot more stable generally right out of the box so its not as big of a risk anymore. We used to stick to strictly GD code but we don't do that anymore either. I'm not sure they still even do GD code anymore for anything other than routers anyway , maybe one of the cisco guys could comment on that . I know I never see GD code for any of the switches since catos went away .
cowetacoit Wed, 06/04/2008 - 17:05
For some reason i tried loading that new IOS 5 different times and it wouldn't work.
first
copy tftp flash
ip add
source cat4500-ipbasek9-mz.122-44.SG.bin
dest cat4500-ipbasek9-mz.122-44.SG.bin
conf t
boot system flash cat4500-ipbasek9-mz.122-44.SG.bin
then i did a reload. But it didn't take the new IOS. I currently have cat4000-i9s-mz.122-18.EW3.bin on my 4506. The only difference i see is the old image file has "4000" and the new has "4500". Do i need to load a earlier image before i can load the newest? When i go to the IOS page for the 4506 sup 4, i apparently i have the oldest IOS on the page.
any suggestions would be helpful.
Admin_4506#sh ver
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(18)EW3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Mon 07-Feb-05 19:21 by hqluong
Image text-base: 0x00000000, data-base: 0x010BFA78
ROM: 12.2(20r)EW1
Dagobah Revision 95, Swamp Revision 29
Admin_4506 uptime is 12 minutes
System returned to ROM by reload
System restarted at 00:55:35 UTC Thu Jun 5 2008
System image file is "bootflash:"
cisco WS-C4506 (MPC8245) processor (revision 7) with 524288K bytes of memory.
Processor board ID FOX0929063J
Last reset from Reload
30 Virtual Ethernet/IEEE 802.3 interface(s)
144 FastEthernet/IEEE 802.3 interface(s)
44 Gigabit Ethernet/IEEE 802.3 interface(s)
403K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Jon Marshall Wed, 06/04/2008 - 17:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Try setting your configuration register to 0x2102. With 0x2101 the switch will load the first image it finds in bootflash and will ignore your boot system variables.
Jon
cowetacoit Wed, 06/04/2008 - 17:50
humm....good idea. Of course i have to wait till tomorrow night to do it. Don't you hate having to do major maintenance after hours!!!!! Any other suggestions?
Jon Marshall Wed, 06/04/2008 - 18:18
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Not really. You are going to have reload the switch again anyway. You know that you can set the configuration register from config mode ie.
4500(config)# config-register 0x2102
Jon
cowetacoit Thu, 06/05/2008 - 17:14
Alright, i set my Config-Reg to ox2102, loaded the NEWEST 4506 IOS and it booted to ROMMON. I was running cat4000-i9s-mz.122-18.EW3.bin and upgraded it to cat4500-ipbasek9-mz.122-44.SG.bin. I knew this wouldn't work for some reason. The rommon error said it has to boot with the correct file name, the old said CAT4000 and the new said CAT4500. So now i have 4 images on my switch. How can i safely delete the 3 that i don't need (i tried loading the 2 before the newest) and does anyone have any suggestions on what IOS to load?
Edison Ortiz Fri, 06/06/2008 - 05:21
  • Hall of Fame,
    Founding Member
It means the file name wasn't typed correctly or the location of the file is incorrect.
It happens frequently when you have to type such a long file name.
What I usually do is do a dir in the filesystem and copy and paste the output on the boot system command.
Can you post the dir output along with the boot system command you have in the router config?
As for deleting the images, the command erase followed by the image name should do it.
cowetacoit Fri, 06/06/2008 - 05:24
Sure, Admin_4506#dir
Directory of bootflash:/
1 -rwx 10322612 Aug 25 2005 18:21:27 +00:00 cat4000-i9s-mz.122-18.EW3.bin
2 -rwx 14787732 Jun 5 2008 00:27:41 +00:00 flash
3 -rwx 14787732 Jun 5 2008 00:35:03 +00:00 cat4500-ipbasek9-mz.122-44.SG.bin
4 -rwx 13406880 Jun 5 2008 00:52:42 +00:00 cat4500-ipbase-mz.122-40.SG.bin
61341696 bytes total (8036228 bytes free)
Also i just tried to erase the last 3 in the dir and it wouldn't let me using the command "erase *filename*
cowetacoit Fri, 06/06/2008 - 05:35
erase bootflash:cat4500-ipbase-mz.122-40.SG.bin
This didn't work.
Admin_4506#erase ?
/all Erase all files(in NVRAM)
cat4000_flash: Filesystem to be erased
nvram: Filesystem to be erased
startup-config Erase contents of configuration memory
Correct Answer
Edison Ortiz Fri, 06/06/2008 - 05:37
  • Hall of Fame,
    Founding Member
argh,
try this one:
cowetacoit Fri, 06/06/2008 - 05:40
I actually just tried it.
Admin_4506#delete ?
/force Force delete
/recursive Recursive delete
bootflash: File to be deleted
cat4000_flash: File to be deleted
nvram: File to be deleted
slot0: File to be deleted
Admin_4506#delete bootflash:?
bootflash:cat4000-i9s-mz.122-18.EW3.bin bootflash:cat4500-ipbase-mz.122-40.SG.bin bootflash:cat4500-ipbasek9-mz.122-44.SG.bin
bootflash:flash
ok, so as far as the upgrade....
boot system flash bootflash:cat4500-ipbasek9-mz.122-44.SG.bin
Thanks! I'll try it again tonight.
Edison Ortiz Fri, 06/06/2008 - 05:48
  • Hall of Fame,
    Founding Member
Were you able to delete it?
You can verify by typing dir once again.
How about the boot system command?
Did you modify it per my suggestion?
Noticed, you had the missing location where the file was stored and the ".bin" in the filename was also missing.
Let us know how it goes.
HTH,
__
Edison.
cowetacoit Fri, 06/06/2008 - 06:01
Yes i deleted all but the oldest and the newest.
Yes, the boot system flash "filename" you suggested works.
I did delete the file name "flash" as well.
Thanks for your help. I'll try the upgrade when i can have downtime again.
