06-04-2008 02:12 PM - edited 03-15-2019 11:04 AM
My media says 6.1
When installed, it says 6.1.1.2000-3
So is this version 6.1(1a) or 6.1(1b)
or 6.1(2)
Does it matter with DMA when I got 6.1x? which DMA version I download and use?
Thanks much!
06-04-2008 02:22 PM
What you have should be 6.1.1a.
6.1.1 is 6.1.1.1000-11
6.1.1a is 6.1.1.2000-3
6.1.1b is 6.1.1.3000-2
6.1.2 is 6.1.2.1000-13
Please download the DMA for 6.1.1.a. The executable name should be DataMigrationAssistant-6-1-1a.exe
Sankar
PS: please remember to rate posts!
06-04-2008 02:25 PM
Thanks Shakes!
How did you figure this out?
06-04-2008 02:29 PM
Its simple. You can go to CCO software download and then go to UCM 6.1 downloads-> UCM upgrades -> you can see options to download 6.1.2, 6.1.1, 6.1.1a etc. Once you select one of these options, it lists the file name on to the right hand side. The file name shows the translation as in 6.1.1.2000-2 and so on. For example see the sample file name below
UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part1of2
Sankar.
06-04-2008 07:12 PM
Thanks much Sankar! I have no idea why I call you Shakes all the time! (even when it says Shanky)
Cheers!
06-04-2008 07:28 PM
No worries!!
