Can ASA make PBR feature?
Jun 4th, 2008
Hi, I want to ask about ASA 5510.
I have 2 link to internet (int eth0 and int eth1).
I want to make rule like PBR in router. For example, I want 192.168.1.0/24 (inside) for internet go to eth0 and 192.168.2.0/24 (inside) for internet go to eth1. Can it be done by ASA?
Thx and best regards,
msi
Overall Rating: 4 (1 ratings)
Farrukh Haroon Thu, 06/05/2008 - 02:32
The ASA/PIX does not support PBR to date. I've been told its on the roadmap.
As a work around, you could run multiple contexts, where contextA inside = 192.168.1.0/24 and contextB inside = 192.168.2.0/24
And also allocate the appropriate Internet interfaces to each context (with the default gateway pointing to the respective ISPs).
This link will get you started:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808d2b63.shtml
PLEASE NOTE: Dynamic Routing and VPNs are not supported in Multiple Context mode.
Another alternate, if the WAN links are terminated on a router (and not the firewall), you could use that router to do the PBR.
Farrukh
