cisco 3845
Jun 4th, 2008
Hi I am very much new with IPT technology. Currently we have 3845 cisco routers used as gateway, I want to understand more how to monitor calls with this devices. Are there any sites to read more of troubleshooting and probable problem cause. Thanks
thisisshanky Wed, 06/04/2008 - 22:54
What are you trying to monitor ? Are you trying to listen into calls going across the gateway or are you trying to monitor / troubleshoot problems associated with calls ? If you have a PRI you can use the debug isdn q931 which gives a lot of userful information. There are a lot of commands available to troubleshoot, but if you can post what specific problem you are experiencing, we may be able to help you more.
