dhcp snooping
Jun 4th, 2008
there is no vlans, no radius server yet.
dhcp snooping should be done in a network that contains
2960s and a 4506.
What should be itenarary and
the commands should be inserted the switches
Ryan Carretta Wed, 06/04/2008 - 23:24
  • Bronze, 100 points or more
There are several configuration action items:
* Enable DHCP snooping globally
Switch>enable
Switch#config t
Switch(config)#ip dhcp snooping
* Enable DHCP snooping on the desired VLAN(s)
Switch(config)#ip dhcp snooping vlan
* Configure injection of option-82
Switch(config)#ip dhcp snooping information option
* Configure where you want to store the database bindings
Switch(config)#ip dhcp snooping database :
* If an aggregation switch, configure allowing receipt of DHCP packets from untrusted interfaces when option-82 is present
Switch(config)ip dhcp snooping information option allow-untrusted
* Optionally configure mac-address verification. This will verify that the layer-2 header source mac of a received DHCP packet matches the client address in the dhcp header.
Switch(config)#ip dhcp snooping verify mac-address
* Configure the upstream (direction of DHCP server) interface as a trusted port
Switch(config)#int gig0/1
Switch(config-if)#ip dhcp snooping trust
* Optionally configure the number of packets per second an interface should be able to inspect. Configuration of this can protect the control plane of the CPU from a denial of service attack initiated by faulty DHCP client/server software or by a malicious user. We recommend not allowing more than 100 packets/sec from untrusted interfaces.
Switch(config-if)#ip dhcp snooping limit rate
For the database binding agent, refer to these links:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_44_se/configuration/guide/swdhcp82.html#wp1282423
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_44_se/configuration/guide/swdhcp82.html#wp1282651
