H-REAP vlan-mapping
Jun 4th, 2008
I have to locations with wlc in an redundant configuration. For one wlan I use the H-REAP feature. I defined the management-interface for that wlan. The wlan configuration on both wlc is identical. One difference is in the management-interface configuration. On the first wlc the management-interface is tagged with vlan 55 and on the second wlc the interface is untagged.
With this configuration the vlan-mapping change if the ap join the other wlc. When the ap leave the first wlc to the second wlc in the vlan-mapping appear vlan 1 instead of vlan 5. In the other way the vlan-mapping change to vlan 55 instead of vlan 5. It seems that the tagging of the management-interface is the problem. Is that true or exists other problems?
Overall Rating: 4 (1 ratings)
Scott Fella Thu, 06/05/2008 - 04:42
You should have the management interface set to "0" untagged ans the switchport native vlan 55. This should solve your problem.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
