CISCO-CONFIG-COPY missing OID 12.4-15 T1
Jun 5th, 2008
we usually use the SNMP-Copy-Method for saving configuration to a tftp server.
Last week we installed a new 876 IOS 12.4-15 T1. Tried to copy the config via snmp and it failed. Checking the oid's showed that the OID-Tree 1.3.6.1.4.1.9.9.96 isn't there! Any other OID works! Why? Any suggestions?
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 06/05/2008 - 09:03
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The objects in the CISCO-CONFIG-COPY-MIB are implemented as read-create which means a walk of this MIB would should nothing unless you created a config copy operation, and instantiated a row in the ccCopyTable. I don't know the exact feature set running on your 876, but I know the CISCO-CONFIG-COPY-MIB is supported in ADVIPSERVICES, and if you try setting the objects in the ccCopyTable, it should work.
