IOS Server Load Balancing question
Jun 5th, 2008
Does anyone know what is the "sticky group" number used for?
Thanks in advance.
lamav Thu, 06/05/2008 - 10:14
You use that command to assign servers to a group, if you want, and then assign a sticky time for the connections made to them.
Rajat Chauhan Thu, 06/05/2008 - 10:42
The "group" keyword and "group-id" argument tie multiple virtual servers together.
For example, lets say we have three public web servers and two restricted web servers. The public web servers are weighted according to their capacity, with the lowest capacity having a connection limit imposed on it.
The restricted web servers are configured as members of the same sticky group, so that HTTP connections and Secure Socket Layer (SSL) connections from the same client use the same real server.
