netflow per vlan
Jun 5th, 2008
Good day everyone!
device: MSFC2(C6MSFC2-BOOT-M), Version 2.1(8a)EX.
A_Root(config)#interface Vlan 15
A_Root(config-if)#ip route-cache flow
Q: When I do 'show ip cache flow', only 1 packet per IP is printed(see attached file).
thank you very much.
Overall Rating: 3 (2 ratings)
Jan Nejman Thu, 06/05/2008 - 02:14
you need to enable mls netflow...
Try the following commands:
switch(config)# mls nde sender version 7
switch(config)# mls aging long 128
switch(config)# mls aging normal 16
switch(config)# mls netflow
On the Supervisor Engine 1 issue the following to put full flows into the netfow exports:
switch(config)# mls flow ip full
If you have a Supervisor Engine 2 or 720 running IOS version 12.1.13(E) or higher, issue the following commands instead:
switch(config)# mls flow ip interface-full
Thats, all.
Kind regards,
Jan Nejman
Caligare, Co.
rtelematicas Thu, 06/05/2008 - 03:12
MLS is already enabled, because only the first packet is routed through the MSFC, the remaining packets are switched on the Supervisor.
on switch:
set mls flow full
set mls nde enable
MLS commands supported on MSFC:
A_Root(config)#mls ?
ip ip keyword
rp rp
A_Root(config)#mls ip ?
acl Enable ACLs particular features
multicast multicast keyword
A_Root(config)#mls rp ?
ip Enable IP shortcuts
ipx Enable IPX shortcuts
nde-address nde-address
A_Root(config)#mls rp ip ?
input-acl Enable IP input access list
route-map Enable IP route map
A_Root(config)#mls rp nde-address ?
A.B.C.D IP address
Jan Nejman Thu, 06/05/2008 - 03:36
ohh, you are using CatOs on the switch and IOS on the MSFC.
The first packet goes to the MSFC where is "routed", the switch learn it and other packets go directly via switching part (on the supervisor). So I think that it is correct, if you see only one packet per flow. Did you configure correctly netflow export on the supervisor? See our webpages: (section configuration).
Could you send me configuration of your CatOS?
Your MSFC configuration is OK.
Kind regards,
rtelematicas Thu, 06/05/2008 - 04:08
interface Vlan15
ip address x.x.x.x
ip route-cache flow
ip flow-export source Vlan15
ip flow-export version 5
ip flow-export destination 9994
On Catalyst:
set mls flow full
set mls agingtime 128
set mls nde enable
### I suppose this version of IOS does not allow to enable Netflow on the MSFC.
Jan Nejman Thu, 06/05/2008 - 04:16
I think, that your msfc configuration is really OK. But you haven't specified an export destination from your switching part.
switch> (enable) set mls nde 9994
switch> (enable) set mls nde version 7
switch> (enable) set mls agingtime long 128
switch> (enable) set mls agingtime 16
If you are using CatOS on the supervisor, and IOS on the MSFC, it is neccessary to configure netflow export destinations for both parts!
In the MSFC you will see only the first packet and on the supervisor (CatOS) the rest of communication (99% flows). I recommend to use the same IP address and port number for both parts (if your analyzer supports it).
rtelematicas Thu, 06/05/2008 - 04:43
When I do configure netflow export destinations for both parts, it works., the problem is that all traffic is exported, not only traffic from Vlan 15., but it's OK, thank you very much for the support.
Jan Nejman Thu, 06/05/2008 - 04:52
On the supervisor there is not any mechanism, how to specify from which VLANs or ports do you want to collect a netflow. If you want to see a separate traffic flow, it is neccessary to use some filtering method on the analyzer side. I'm coding Caligare Flow Inspector software, and there are two ways how to filter flow a) you can drop unwanted flows when you receive it or b) when you specify query it is possible to set filtering conditions based on (IP addresses, interfaces, ports, ...), but in the database there are all flows.
Kind regards,
PS.: One interesting command is: set mls bridged-flow-statistics enable ... (it will account intra-vlan flows, e.g. flows that goes from vlan 15 to vlan 15), but it generates many many flows....
rtelematicas Thu, 06/05/2008 - 05:04
ok, I will use filtering conditions(set mls nde flow include source...).
thanks again.
droberts1965 Wed, 07/18/2012 - 08:57
Hi there guys.  Can anyone please tell me where i can go to get help on a problem i have with a 2801 router and using ip flow-export?  I entered the following commands into my router and then the router dropped all outgoing TCP traffic.  I disabled all the commands and my path out reopened.
snmp-server ifindex persist
ip flow-export destination 9996
ip flow-export source FastEthernet 0/1
ip flow-cache timeout active 1
int fa0/0
no ip route-cache flow
ip flow egress
int fa0/1
ip flow egress
once this is entered then all TCP traffic heading outside is blocked...
Thanks for any help..
