Attendant Console and the Windows
Answered Question
Jun 5th, 2008
i'm on search for a simple solution. In the Attendant Console (I use 5.1(3)) it is not possible to switch between the windows where calls come in and the directory window with a shortcut.
I tried many Shortcuts... But no solution.
Has anyone the same problem?
The thing is, that the users will not use the mouse. They only want to use keyboard. Need some help :(
Thanks for your replies...
Chris
Correct Answer by smalkeric about 8 years 10 months ago
Overall Rating: 5 (1 ratings)
