DID configuration help
Jun 5th, 2008
I am using CME 4.1.I want o enable Direct inward dialing in my router.My pstn no is 024481415 and my extension is in range of 200-300.
My requirement is when somebody call to my PSTN no: with extension .the call should go to the corresponding extension without going to reception.
under telephony-service i have configured below command
dialplan-pattern 1 0244814152.. extension-length 3 extension-pattern 2..
it is not working after giving the above command
i think some extra configuration is needed.I am entirely new to voip.Please help me out to solve my problem.
Overall Rating: 5 (1 ratings)
Adrian Saavedra Thu, 06/05/2008 - 06:27
  • Gold, 750 points or more
Hi friend,
Please check this links, may be helpful.
Dial-Plan Patterns, DID Trunk Lines and SCCP Configuring Dial-Plan Patterns:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmedialp.html#wp1056041
Matching the Correct Inbound POTS Dial Peer for DID:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00801142f8.shtml#did_cfg
- adrián.
