Layer 2 switch Security
Jun 5th, 2008
Hi is it possible to configure a layer two switch with security i.e ACL and QOS
Overall Rating: 3 (1 ratings)
network_team Thu, 06/05/2008 - 23:20
Hi what i want to do is a link two sites together using 3550SMI layer 2 switch, but i only want the remote site to connect to some enviroments and block them to others
Farrukh Haroon Fri, 06/06/2008 - 03:01
Please have a look at the following link:
Please make sure you understand the 'login' of VLAN access-maps before you implement them, or you could end up denying legitimate traffic.
Make sure you put 'action forward' in your second sequence number (After doing 'action drop' for the desired the first sequence number).
