IOS SSL VPN problem
ROBERTO TACCON
Level 4
Level 4
I am implementing a SSL VPN with IOS version 12.4(13r)T5 on a 2801 but when I try to connect to the tunnel mode with the latest svc (anyconnect-win-2.2.0133-web-deploy-k9.exe) with https://1.2.3.4/tunnel the ssl vpn client can't connect.
The error on the router is:
Jun 5 16:07:55.755: WV: Appl. processing Failed : 2
Jun 5 16:07:55.755: WV: server side not ready to send.
The following is the configuration:
ip local pool WEBVPN 10.0.0.140 10.0.0.150 group vpn2
webvpn gateway ISR2801-RM
hostname ISR2801-RM
ip address 1.2.3.4 port 443
ssl trustpoint TP-self-signed-50153718
inservice
webvpn install svc flash:/webvpn/svc.pkg
webvpn install csd flash:/webvpn/sdesktop.pkg
webvpn context vpn1
ssl authenticate verify all
url-list "eng"
url-text "wwwin-eng" url-value "http://wwwin-eng.cisco.com"
policy group vpn1
url-list "eng"
default-group-policy vpn1
gateway ISR2801-RM domain clientless
inservice
webvpn context vpn2
policy group vpn2tunnel
functions svc-enabled
svc address-pool "WEBVPN"
svc split include 10.0.0.2 255.255.255.255
default-group-policy vpn2tunnel
gateway ISR2801-RM domain tunnel
inservice
8 Replies 8
Farrukh Haroon
Is your pool in the same subnet as the inside interface?
Try to compare your configuration from the following link , maybe you are missing something?
http://www.cisco.com/en/US/products/ps6496/products_configuration_example09186a0080720346.shtml
Farrukh
Also, I think you need to be running at least 12.4(15)Tx, to support the AnyConnect client, have a look at:
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/htwebvpn.html#wp1393624
Farrukh
Thanks for the reply !!!!
the configation is the following:
interface Ethernet 0
ip address 10.0.0.128 255.255.255.0
ip http secure-server
ip local pool WEBVPN 10.0.0.140 10.0.0.150 group policy-sslvpn2
hostname ISR2801-RM
ssl encryption aes-sha1
inservice
webvpn context context-sslvpn1
user-profile location flash:webvpn/sslvpn/context-sslvpn1/
url-list "eng"
nbns-list cifs-servers
nbns-server 172.16.1.1 master
nbns-server 172.16.2.2 timeout 10 retries 5
nbns-server 172.16.3.3 timeout 10 retries 5
login-message "UNAUTHORIZED ACCESS TO THIS NETWORK DEVICE IS PROHIBITED. You must have explicit permission to access this device. All activities performed on
this device are logged and violations of this policy may result in disciplinary action."
port-forward "portlist"
local-port 30019 remote-server ssh-server remote-port 22 description SSH
local-port 30020 remote-server mailserver remote-port 143 description IMAP
local-port 30021 remote-server mailserver remote-port 110 description POP3
local-port 30022 remote-server mailserver remote-port 25 description SMTP
policy group policy-sslvpn1
url-list "eng"
nbns-list "cifs-servers"
functions file-access
functions file-browse
functions file-entry
citrix enabled
default-group-policy policy-sslvpn1
inservice
webvpn context context-sslvpn2
user-profile location flash:webvpn/sslvpn/context-sslvpn2/
policy group policy-sslvpn2
svc keep-client-installed
svc dpd-interval gateway 30
svc dpd-interval client 300
svc rekey method new-tunnel
svc rekey time 3600
svc split include 10.0.0.0 255.255.255.0
svc default-domain cisco.com
svc dns-server primary 192.168.3.1
svc dns-server secondary 192.168.4.1
default-group-policy policy-sslvpn2
inservice
ISR2801-RM#show webvpn install status svc
SSLVPN Package SSL-VPN-Client version installed:
CISCO STC win2k+
2,2,0133
Mon 05/19/2008 12:58:52.34 v
ISR2801-RM#
WHEN I TRY TO CONNECT TO THE SSL CONTEXT 2 with a client
* the ssl client installed on the pc tell me can't connect.
* on the router the log:
Jun 6 10:28:08.283:
Jun 6 10:28:08.283:
Jun 6 10:28:08.283: WV: Entering APPL with Context: 0x6AA85130,
Data buffer(buffer: 0x6C4B4280, data: 0xF5C043D8, len: 560,
offset: 0, domain: 0)
Jun 6 10:28:08.283: CONNECT /CSCOSSLC/tunnel HTTP/1.1
Jun 6 10:28:08.283: Host: host4-234-static.105-80-b.business.telecomitalia.it
Jun 6 10:28:08.283: User-Agent: Cisco AnyConnect VPN Agent for Windows 2.2.0133
Jun 6 10:28:08.283: Cookie: webvpn=00@1566900393@00025@3421729574@3982902438@context-sslvpn2
Jun 6 10:28:08.287: X-CSTP-Version: 1
Jun 6 10:28:08.287: X-CSTP-Hostname: telefonicadata
Jun 6 10:28:08.287: X-CSTP-Accept-Encoding: deflate;q=1.0
Jun 6 10:28:08.287: X-CSTP-MTU: 1406
Jun 6 10:28:08.287: X-CSTP-Address-Type: IPv6,IPv4
Jun 6 10:28:08.287: X-DTLS-Master-Secret: 27EA2210E377A9E039E458FA604F523C69BEB2BF8D9B40334F72C9F424B83EE26C6D5D57D0F84419DC7A1139D3F08EE9
Jun 6 10:28:08.287: X-DTLS-CipherSuite: AES256-SHA:AES128-SHA:DES-CBC3-SHA:DES-CBC-SHA
Jun 6 10:28:08.287:
Jun 6 10:28:08.291:
Jun 6 10:28:08.291:
Jun 6 10:28:08.291: WV: Appl. processing Failed : 2
Jun 6 10:28:08.291: WV: server side not ready to send.
SSLVPN sock pid 182 sid 161: closing
Hello, config seems OK, Since your IP pool is on the same subnet as the LAN, thats also ok. Otherwise you have to create a loopback.
Anyway did you upgrade you IOS from 12.4(13r)T5 to 12.4(15)Tx ? (As mentioned in my last post). This is required for the 'new' Anyconnect client to work. You can only run the Cisco SSL VPN Client (SVC) on your IOS version.
Please re-read my last post. Regards
Farrukh
Also for your Clientless context, I don't think the following will work, SSH needs special handling (like the ASA firewall has a separate plugin for this). I don't think the IOS SSL VPN supports this to date? If you got it working please let me know also :). I need it for one customer.
Farrukh
the IOS version on the cisco 2801 is the last: c2801-advipservicesk9-mz.124-15.T5.bin
and need to deploy only (for now) the context context-sslvpn2 (the one with Tunnel Mode-Full tunnel client mode).... but the error on the log remain.
Just a q:
if the ssl vpn client need to do a slip tunnel (connect the pool on the ssl tunnel only vs the network 10.0.0.0 /24) the following is correct ?
Thanks again for your time.
RT
Yes, this systax seems correct, more details can be found here:
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/htwebvpn.html#wp1354672
why don't you enable detailed debugging on the ROUTER and attach here?
debug webvpn tunnel
debug webvpn authentication
debug webvpn aaa
debug webvpn cookie
debug webvpn package
debug webvpn entry
Also one important thing, in Internet Explorer:
Tools >> Internet Options >> Advanced
Check "Use SSL 3.0" and "Use SSL 2.0"
Clear Browse Cache/Cookies
Farrukh
you could try to remove the "domain clientless" extension defined in your webvpn context :
#gateway ISR2801-RM domain tunnel
I had the same issue and I believe that the domain is somehow linked to the trustpoint, so while the domain declared is not part of the selfsigned certificate defined in trustpoint, there is no need for the option domain tunnel;
