ATM EIGRP connection flapping
Jun 5th, 2008
Summary: we recently upgraded a router and circuit at one site. Router was upgraded to a 3825 from a 3640, circuit upgraded from a 3xATM/IMA to a 15 Mbit ATM DS3. All prior connections reconnected, and are working fine, except one.
Once a minute, every minute, a get the syslog EIGRP message (truncated) on this pvc:
06-05-2008 09:29:21 Neighbor (ATM1/0.35) is up: new adjacency
06-05-2008 09:29:21 Neighbor (ATM1/0.35) is down: retry limit exceeded
All EIGRP timers are default settings; I have run pings without any losses; I am not getting any other messages related to the other pvc on this new router.
SH IP EIGRP NEI shows a Q CNT of 1 on this link.
I am getting quite a few input errors and giants on the other end of this circuit, which is a frame-relay btw. It also has an mtu of 1500, whereas I think the 3825 has a mtu of 4470. No other errors seen on 3825 at interface or pvc (subinterface) level.
Thanks in advance. Patrick
Overall Rating: 4 (1 ratings)
Sharkey13 Thu, 06/05/2008 - 08:40
sh controller has a rather lenghty output. Is there something in particular to look for?
ruwhite Mon, 06/09/2008 - 03:28
This is probably layer 2.... Try a couple of things. First, ping to I'm guessing this is working, because you're building an adjacency in the first place, but it's always where I start anyway. Then pint unicast between the two routers, say 10000 packets, with a very low timeout, say 0 seconds.
Next, try pinging with a range of sizes (it's under the advanced options in the ping command--don't put in an address, just do ping, then follow the prompts, and when it asks you for advanced options, say yes). Make certain you put the final size as what the MTU for the link should be.
I'm guessing you either have unidirectional unicast only, unidirectional multicast only, or an MTU problem on the link. It's far too consistent to be random errors, I think.
Sharkey13 Mon, 06/09/2008 - 07:45
Russ - thank you for the reply.
Ping to is successful on both routers.
Unicast ping from either router to the other, 5000 packets, 0 timeout, 0% successful.
Ping range of sizes: (the results were the same from each router, only one posted):
Protocol [ip]:
Target IP address:
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]: 0
Extended commands [n]: y
Source address or interface:
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]: y
Sweep min size [36]:
Sweep max size [18024]: 1500
Sweep interval [1]:
Success rate is 0 percent (0/7325)
I look forward to your response and interpretation of these results.
Thanks, Patrick
Sharkey13 Mon, 06/09/2008 - 10:24
Russ - your post led me to the solution for this issue.
I changed the mtu on the ATM subinterface in question of the new router to 1500, which matches the frame-relay interface mtu on the corresponding router. Syslog errors stopped immediately.
Thanks for providing some insight on where to look for a solution.
