Sending to Voice Mail after Hunt.
j98me2
I have some calls that are set to route to a route/hunt group. This then goes to a line group. It successfully rings the extensions in the line group. The problem is if nobody picks up it drops to a fast busy signal. How do I make it finish into a voice mail box?
if your version does not have the option just add the VM ports line group at last of the groups and create a call routing rule in unity for calls coming from that pilot
javalenc
if this helps, please rate
java
7 Replies 7
thisisshanky
Level 11
Level 11
You can set this option on the huntpilot configuration page where you can forward on busy or no answer of the hunt pilot to a CTI route point that is call forwarded to voicemail.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
I dont see that option in Route Patterns/Hunt Pilots
javalenc
java
what version callmanager are u on ?
4.x and later you should see
Hunt forward settings...
Sankar Nair
Perhaps I am looking in the wrong place. I am looking in the drop down under route plan then route pattern/hunt pilot
Hi Jeremy,
Just to add a note to the good info from Shanky and Jaime;
Route Plan > Route Hunt > Hunt Pilot (Find specified Hunt Pilot #) > Hunt Pilot Configuration > Hunt Forward Settings > Forward Hunt No Answer (enter VM Pilot #)
Hope this helps!
Rob
I used the mesage from javalenc and it worked perfect.
