Prevent return dialtone on Inbound FXO port call (H.323 SRST)
Jun 5th, 2008
Is there a way to have inbound calls to specific voice ports disconnect. Currently they are matching a peer and returning dialtone. We would liek the call to just disconnect or Ring no answer
dial-peer voice 91 pots
description SRST
preference 2
destination-pattern .T
port 0/1/1
voice-port 0/1/1
timeouts interdigit 3
timing hookflash-out 500
caller-id enable
Overall Rating: 3 (1 ratings)
Aaron Dhiman Mon, 06/09/2008 - 10:10
You can force it return busy tone by PLAR'ing it (Private Line Automatic Ringdown) to a non-existant number.
voice-port 0/1/1
connection plar 8888
Assuming that 8888 is not routable by the gateway, then the call presented from the LEC to 0/1/1 will get busy tone. You'll still be able to make calls out of that line to the LEC just fine.
