FM 3.2(2c) - can't discover 2nd fabric
Answered Question
Jun 5th, 2008
I use Fabric Manager SA 3.2(2c) on Windows XP to administer my local 9509. I'm trying to discover a 9513 fabric at our DR site - here's what happens:
1) login to FM
2) Goto Control Panel Fabrics tab, click Discover
3) Enter IP of 9513 for Seed Switch
4) Enter my account User Name and Password
5) Click Discover
Several seconds later:
ERROR Discover New Fabric
Snmp: timeout
I can SSH into the 9513 with my account and also contact it with my web browser.
Any suggestions?
Correct Answer by stephen2615 about 9 years 2 weeks ago
Is there a firewall/ACL in between sites that has blocked SNMP traffic? Its not uncommon sometimes and lots of organisations allow ssh and http but have real concerns with SNMP and will often block the ports. Universities in particular have to be extra vigilent just because of their students...
An easy way to test it is to put FM on a system at the remote site and try to discover the switch there. Is there another SNMP enabled device in the DR site you (or the network people) can try an snmpget/snmpwalk on?
Stephen
Overall Rating: 5 (1 ratings)
Correct Answer
stephen2615 Fri, 06/06/2008 - 18:19
  • Bronze, 100 points or more
Stephen
sysfhw Mon, 06/09/2008 - 08:51
Thank you very much for your reply. I know that the admins at the remote site can use FM with that switch, so I'll check about the ACLs and see if that's my problem.
Frank
sysfhw Mon, 06/16/2008 - 09:33
There was a rule to allow SNMP access for me in the remote site's border router, BUT it allowed access to the old SAN switch's IP. My colleagues changed the rule to include the IPs of the two new switches and now the discovery is working for me. Thanks for your help!
Frank
Trending Topics: Storage Networking
