sdoremus33 Sat, 06/07/2008 - 08:20
  • Bronze, 100 points or more
Could you explain further the connection between these hosts I assume that CE-PE connection has problem how is the connection established MP-BGP , static?
Can you ping the egress interface of the PE router from Ce router and also ping via the routing instance
Ex
1) Regular ping from CE to Egress PE
ping
[ip]
address
ping ip address vpn instance
Ex :(See Below)
Ping
Ping x.x.x.x routing instance vpn#. HTH
