Can't access outside or internet once connected
Jun 5th, 2008
I have pix 525 with 8.03 ios and adsm 6 installed.
remote vpn configured fine, cisco vpn client installed fine.
but after the connection, I can't access any hosts outside of 10.0.0.x(inside) subnet.
I can't even ping my outside NIC
attached is my config.
msubtain Thu, 06/05/2008 - 19:37
I can not access your config for some reason, can you post it here?
check few things, have you enabled split tunneling? if yes have you defined network list?
dkim777oig Fri, 06/06/2008 - 05:19
sorry, somehow expiration date was the same date as post date.
PIX Version 8.0(3)
hostname was-pix
domain-name home
enable password xxx
interface Ethernet0
nameif outside
security-level 0
ip address
interface Ethernet1
nameif inside
security-level 100
ip address
interface Ethernet2
no nameif
no security-level
no ip address
passwd xxx
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
domain-name home
access-list outside_access_in extended permit ip any any
access-list outside_access_in_1 extended permit ip host any
access-list inside_access_in extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
ip local pool vpn-pool mask
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image flash:/asdm-603.bin
no asdm history enable
arp timeout 14400
global (outside) 101 interface
nat (inside) 101
access-group outside_access_in_1 in interface outside control-plane
access-group inside_access_in in interface inside
route outside 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http inside
http outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh outside
ssh timeout 5
ssh version 2
console timeout 0
management-access inside
threat-detection basic-threat
threat-detection statistics
ntp server source outside
group-policy vpn-group internal
group-policy vpn-group attributes
dns-server value
vpn-tunnel-protocol IPSec
default-domain value home
username user1 password xxx encrypted privilege 0
username user1 attributes
vpn-group-policy vpn-group
tunnel-group vpn-group type remote-access
tunnel-group vpn-group general-attributes
address-pool vpn-pool
default-group-policy vpn-group
tunnel-group vpn-group ipsec-attributes
pre-shared-key *
prompt hostname context
: end
dkim777oig Fri, 06/06/2008 - 06:48
Well, I want ALL traffic(including internet) to go through VPN, therefore I haven't enabled split tunnel.
Is there any other way?
