CRSJavaAdmin.exe crashes. Can't get into AppAdmin
Jun 5th, 2008
Has anyone seen the CRSJavaAdmin.exe crash before? Every time I try to start it to access the AppAdmin pages, it stops after 2-3 seconds. the CRSJavaEngine.exe and CRSJavaService.exe are both running fine.
Just completed the upgrade process from 3.5 to 4.0 and I can't get back into the system to configure the CCM integration.
htarra Wed, 06/11/2008 - 12:06
CRSJavaAdmin.ex.exe - Crash... Try this bug CSCsl98130 and There is a bug related to a Java memory leak in 4.0(4) that is fixed in SR1. When Java runs out of memory, the server processes reboot. The bug id is CSCse18183. You can search for this on and then click "Search the Bug Toolkit" for more info.
