Unity 4.2 Exchange Alias Change
Jun 5th, 2008
I have Unity 4.2 with UM setup and Exchange 2003.
I have to edit a few Subscribers to reference different Exchange alias. SA GUI does not allow that, none of the Unity Depot tools seem to allow it and the only way I have seen doing it is to edit Subscribers table in UnityDb.
Had anyone done it this way, cause it seems pretty simple? Any caveats encountered?
Michael Owuor Thu, 06/05/2008 - 14:57
Hi David,
Change the alias in MS Active Directory instead. The change should consequently be propagated to the Unity database.
Aaron Harrison Sun, 06/08/2008 - 09:03
Not sure what you're trying to do here:
1) Change Exchange alias - if you change this in AD, it will sync into Unity (no change required on Unity)
2) Change a Unity account to point at a different AD account? - if this is what you want to do, use the 'Subscriber Migration Tool' to re-link to a new account.
Hope this helps
Please rate helpful posts...
