BGP Next hop !
Jun 5th, 2008
hi all, suppose i have 3 routers RA, RB, RC connected to each other like this
RA --> RB --> RC
100 200 300
now when RB propagates any prefixes recieved from RA to RC it modifies the next hop to itself right ? is there any way to retain the ip address of RA when RB advertises to RC, kindly tell me if there is any specific bgp command for this, i tried neighbour next-hop-unchanged but it worked only from ibgp to ebgp peer.
bineshpsm Thu, 06/05/2008 - 20:55
you can set a route-map and specify the next hop that u require.
neighbor route-map NEXT_HOP out
route-map NEXT_HOP
set next-hop
illusion_rox Sat, 06/07/2008 - 00:41
thanks for the feedback, but i knew this method, i am looking for a particular bgp command for this
francisco_1 Sat, 06/07/2008 - 05:02
  • Gold, 750 points or more
How are the routers connected? Is router C on same subnet as router A?. If the receiving router C is on the same subnet, the next hop remains the same. Make sure on router B the next "neighbor ****(router b ip) next-hop-self" command is not enable.
riftjameel Sun, 06/08/2008 - 09:31
BGP theory says that IBGP peers doesn't change the next hop ip address only EBGP peers change the next hop ip address.
I hope confederation fixes ur problem
foxbatreco Sun, 06/08/2008 - 16:04
  • Bronze, 100 points or more
the default behaviour would be to advertise the NH as the ebgp peer only, in this case RA.But you can force RC to use NH as RB by using the next-hop-self option with the neighbor command & this works within iBGP only.
Rate if this helps!!!
