changing AP names in bulk with wcs 5 and controller 4.2.112
Jun 5th, 2008
Has anyone tried the new feature in wcs 5 under configure AP's. You can use a csv file to bulk configure AP's.
I'm running wcs 5.0 but my controllers are 4.2.112. Will this feature work, it would allow me to configure the names of more then 100 aps by pushing 1 file.
Scott Fella Fri, 06/06/2008 - 04:11
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Might not be supported. You want to try to keep WLC and WCS versions on the same level and as close to the same as possible. Some code on WCS 5 is made for WLC 5 and most likely will not be supported in a lower version.
Trending Topics - Security & Network
