Unable to Telnet...............
Jun 6th, 2008
Posted by: vatsey.sharad - Engineer, HCL Comnet
Jun 6, 2008, 2:09am PST
I have two IP's Configured on my Cisco 2800. 1.1.1.1 - Loopback and 2.2.2.2 on Fast Ethernet. Both IP's are pingable across the WAN. And telnet to loopback IP is working fine. However I am unable to telnet to Fast Ethernet IP. The error message while trying to telnet to Fast Ethernet IP is: "Could not open connection to the host, on port 23: Connect failed". I tried to debug telnet on the router. The Debug output for unsuccessful telnet is as follows:
_______________________________________
Telnet194: recv SB NAWS 139 24
However for a successful telnet session, the output is:
Telnet195: 1 1 251 1
TCP195: Telnet sent WILL ECHO (1)
Telnet195: 2 2 251 3
TCP195: Telnet sent WILL SUPPRESS-GA (3)
Telnet195: 80000 80000 253 24
TCP195: Telnet sent DO TTY-TYPE (24)
Telnet195: 10000000 10000000 253 31
TCP195: Telnet sent DO WINDOW-SIZE (31)
TCP195: Telnet received DO ECHO (1)
TCP195: Telnet received DO SUPPRESS-GA (3)
TCP195: Telnet received WILL TTY-TYPE (24)
Telnet195: Sent SB 24 1
TCP195: Telnet received WILL WINDOW-SIZE (31)
Telnet195: recv SB NAWS 110 52
Telnet195: recv SB 24 0 ANSI
There are no ACL's or firewalls involved in the picture.
Richard Burts Fri, 06/06/2008 - 03:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sharad
How many forums did you post this question in? I have already found it in 2 other forums.
Rick
