Voice Vlan Recording SPAN/RSPAN
Jun 6th, 2008
We have 2 x 4506 switches & phones plugged into both in voice vlan 220.
Vlan 220 is trunked between both switches.
We have a Nice recorder with one span NIC, which plugs into switch one Gi2/8.
I have the below config on switch 1.
monitor session 1 source vlan 220
monitor session 1 destination interface Gi2/8
It seems that only phones on switch one are recorded and phones on switch 2 are not.
I have tried using RSPAN, but with that config even phones on switch one are not recorded.
Your help will be much appreciated.
Irfaan
Paolo Bevilacqua Fri, 06/06/2008 - 02:46
  • Hall of Fame,
    Founding Member
Hi, can you span on the switch that connected the GW ? This way all calls to PSTS should be recordable.
standardbankcco Fri, 06/06/2008 - 02:59
We have 2 gateways. One on each switch. So its the same problem. By doing it on the vlan we can record internal and external calls, but only for switch one.
