InternVLAN rules on PIX506
Answered Question
Jun 6th, 2008
Hi all,
I need to build up a DMZ with a PIX506. My idea is to make a trunk between PIX and switch, assign a VLAN for the DMZ.
Mi question is, can PIX506 handle firewall-rules between the VLAN's (internal <-> dmz)?
Thank's,
Norbert
Correct Answer by Jon Marshall about 8 years 9 months ago
Norbert
Not sure what you are asking here. The 506E supports up to 2 vlans on an interface so you can do what you want. Each vlan interface is treated as a physically separate interface in terms of security levels/access-lists etc.
So if you have an inside and a DMZ on the same interface you can apply separate access-lists to each interface.
Does this answer your question ?
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Fri, 06/06/2008 - 03:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Norbert
Jon
alig.norbert Fri, 06/06/2008 - 04:58
Jon
Thank's for the answer.
Yes I want to control the traffic between DMZ (VLAN-xx)<-> inside (VLAN-yy) over the PIX.
Greets,
Norbert
