IPS Auto Update failing
craig-allen
I've configured the signature auto update via the GUI and CLI but receive the same error:
evError: eventId=1210198298109812431 vendor=Cisco severity=error
originator:
hostId: LON-Sensor
appName: mainApp
appInstanceId: 341
time: Jun 06, 2008 03:00:07 UTC offset=60 timeZone=BST
errorMessage: MainApplication::downloadAndStartUpdate Error status returned with status str Found name=errSystemError
Any ideas? I've rebooted both the IPS & ASA in the hope that would resolve the problem to no avail. I have another ASA/IPS in a different site and that works ok.
16 Replies 16
jamesand
Send the output from a CLI "show conf" and "show stat host" command.
Hopefully the following sanitised config is what you are looking for:
auto-upgrade
cisco-server enabled
schedule-option calendar-schedule
times-of-day 03:00:00
days-of-week sunday
days-of-week monday
days-of-week tuesday
days-of-week wednesday
days-of-week thursday
days-of-week friday
days-of-week saturday
exit
user-name xxxx
password xxxx
cisco-url https://198.133.219.25//cgi-bin/front.x/ida/locator/locator.pl
exit
exit
exit
Auto Update Statistics
lastDirectoryReadAttempt = 03:00:05 UTC Fri Jun 06 2008
= Read directory: http://xxxx@198.133.219.243//cisco/ciscosecure/ips/6.x/sigup/
= Success
lastDownloadAttempt = 03:00:07 UTC Fri Jun 06 2008
= Download: http://xxxx@198.133.219.243//cisco/ciscosecure/ips/6.x/sigup/IPS-sig-S337-req-E1.pkg
= Error: Error status returned with status str Found
lastInstallAttempt = N/A
nextAttempt = 02:00:00 UTC Sat Jun 07 2008
Does your CCO have a 'Cisco Service for IPS contract' associated with it?
Also if you manually do:
http://user@198.133.219.243//cisco/ciscosecure/ips/6.x/sigup/IPS-sig-S337-req-E1.pkg
does it work?
Farrukh
We are having same issue, and here is our config.
It is the Cisco.com auto-update functionality. I actually have two customers with this issue.
Version 6.1.1(E2). I know about the bug if your Cisco username has an @ in it but neither of the customers have an @ in their username. The error I am getting is the same as described in this bug, but it is appending @www.cisco.com to the end of the username for some reason!:-
evStatus: eventId=1041464419413853599 vendor=Cisco
originator:
hostId: HD-IPS-1
appName: mainApp
appInstanceId: 336
time: Dec 08, 2008 10:11:04 UTC offset=0 timeZone=GMT00:00
autoUpgradeServerCheck:
uri: https://philsmithcisco@www.cisco.com//cgi-bin/front.x/ida/locator/
packageFileName: IPS-engine-E3-req-6.1-1.pkg
result: status=true
evStatus: eventId=1041464419413853600 vendor=Cisco
originator:
hostId: HD-IPS-1
appName: mainApp
appInstanceId: 336
downloadUpgradeFile:
uri: https://philsmithcisco@www.cisco.com//cgi-bin/front.x/ida/locator/IPS-engine-E3-req-6.1-1.pkg
result: URI does not contain a valid ip address status=false
evError: eventId=1041464419413853601 vendor=Cisco severity=error
originator:
hostId: HD-IPS-1
appName: mainApp
appInstanceId: 341
errorMessage: MainApplication::downloadAndStartUpdate URI does not contain a valid ip address name=errSystemError
Here is the config from the IPS (I have masked the password):-
service host
network-settings
host-ip 10.1.3.250/24,10.1.3.254
host-name HD-IPS-1
telnet-option disabled
access-list 10.0.0.0/8
access-list 89.21.19.0/26
exit
time-zone-settings
standard-time-zone-name GMT00:00
exit
summertime-option recurring
summertime-zone-name BST
start-summertime
week-of-month fourth
exit
end-summertime
month october
exit
exit
auto-upgrade
times-of-day 10:11:00
days-of-week monday
days-of-week friday
exit
user-name philsmithcisco
password ************
exit
exit
exit
This was all working fine, and then stopped which would indicate Cisco have changed something at their end.
Your sensor's autoUpdate is erroring trying to download an engine pkg. The engine pkg requires crypto access (diff from sigupdate pkg). The error msg can be misleading in this case. Try manually downloading the IPS-engine-E3-req-6.1-1.pkg package from the Latest Upgrade link in page:
http://www.cisco.com/kobayashi/sw-center/ciscosecure/ids/crypto/index.shtml
You will be prompted to accept the crypto agreement. After this, try the autoUpgrade again.
Make sure there are no network devices blocking port 80 / 198.133.219.243
How can I test that?
We tried the following:
telnet 198.133.219.243 443 this was done from the IPS.Did we send it the right way?
By the way I posted the show config and show stat host if you need anything else, please let me know.
Hi:
We are having the same problem.
There is a problem with the link "https://198.133.219.25//cgi-bin/front.x/ida/locator/locator.pl." I am attaching a screen image.
The customer has in order his contract service. The signatures can be downloaded from cisco.com/support/security/IPS.......
The signatures should be downloaded from "https://198.133.219.25//cgi-bin/front.x/ida/locator/locator.pl." but when accesing, the url directs me elsewhere...
Mod Card Type Model
0 ASA 5510 Adaptive Security Appliance ASA5510
1 ASA 5500 Series Security Services Module-10 ASA-SSM-10
Can you help us with this issue??
The URL can be directly accessed by users. There is also additional information that the sensor appends to the URL when doing the request.
Can you get the output of "show stat host"
The output might contain the error message being seen from the sensor.
Also is the sensor having to go through any special devices to access the internet. Any web filtering or web accelerating device between the sensor and the internet may be messing up the connection.
I meant to say that the URL can be accessed by users, but a list of files will not be returned. There is additional information that the sensor appends to the URL in order for cisco.com to return the list of files.
OK.
Let me get the information for you
thanx
Hi:
I was reading about that username can't contain a "@" It is that true? Because the username of my customer have a "@"
This is the 6.1(1) defect: CSCsq30139
It is fixed in 6.1(2) and 6.2(1).
Hi, I got the information :)
show stat host
General Statistics
Last Change To Host Config (UTC) = 14-Jan-2009 14:38:43
Command Control Port Device = GigabitEthernet0/0
Network Statistics
= ge0_0 Link encap:Ethernet HWaddr 00:13:C4:80:C3:C1
= inet addr:192.168.1.11 Bcast:192.168.1.255 Mask:255.255.255.0
= UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
= RX packets:25375769 errors:0 dropped:0 overruns:0 frame:0
= TX packets:2411636 errors:0 dropped:0 overruns:0 carrier:0
= collisions:0 txqueuelen:1000
= RX bytes:2570835196 (2.3 GiB) TX bytes:657595036 (627.1 MiB)
= Base address:0xbc00 Memory:f8200000-f8220000
NTP Statistics
status = Not applicable
Memory Usage
usedBytes = 660455424
freeBytes = 372043776
totalBytes = 1032499200
CPU Statistics
Usage over last 5 seconds = 31
Usage over last minute = 40
Usage over last 5 minutes = 36
Memory Statistics
Memory usage (bytes) = 660455424
Memory free (bytes) = 372043776
lastDirectoryReadAttempt = 08:40:00 GMT-06:00 Wed Feb 04 2009
= Read directory: https://198.133.219.25//cgi-bin/front.x/ida/locator/locator.pl
= Error: AutoUpdate exception: HTTP connection failed [1,111]
lastDownloadAttempt = N/A
nextAttempt = 08:40:00 GMT-06:00 Thu Feb 05 2009
Auxilliary Processors Installed.
! Current configuration last modified Mon Jan 19 17:15:14 2009
! Version 6.2(1)
! Host:
! Realm Keys key1.0
! Signature Definition:
! Signature Update S379.0 2009-01-30
! Virus Update V1.4 2007-03-02
service interface
exit
service authentication
exit
service event-action-rules rules0
overrides deny-attacker-inline
override-item-status Enabled
risk-rating-range 90-100
exit
exit
service host
network-settings
host-ip 192.168.1.11/24,192.168.1.1
host-name sensor
access-list 10.254.254.0/24
access-list 192.168.1.0/24
exit
time-zone-settings
offset -360
standard-time-zone-name GMT-06:00
exit
auto-upgrade
times-of-day 08:40:00
days-of-week monday
exit
user-name ********
password ********
exit
exit
exit
service logger
exit
service network-access
exit
service notification
exit
service signature-definition sig0
signatures 9430 1
status
enabled true
exit
exit
signatures 11018 1
status
enabled true
exit
exit
signatures 12000 0
status
enabled true
exit
exit
signatures 12003 0
status
enabled false
exit
exit
signatures 12020 0
status
enabled true
exit
exit
exit
service ssh-known-hosts
exit
service trusted-certificates
exit
service web-server
exit
service anomaly-detection ad0
exit
service external-product-interface
exit
service health-monitor
memory-usage-policy
enable true
exit
exit
service analysis-engine
virtual-sensor vs0
physical-interface GigabitEthernet0/1
exit
exit
