CME gui interface
Answered Question
Jun 6th, 2008
I want to enble the cme gui web interface what files shoult I upload to the flash memory and how can I do it?
Correct Answer by Kenneth Mohammed about 8 years 7 months ago
what version of cme are you running? You may already have the gui files on flash, and you just have to unzip them.
Step 1
Download the appropriate cme-gui-x.x.x.tar file to a TFTP server, substituting the Cisco CME release you're using for x.x.x.
Step 2
Log on to privileged EXEC mode on the router.
Step 3
Enter the archive command to extract the contents of the .tar file to the routers flash memory:
router#archive tar /xtract tftp://ip address/cme-gui-x.x.x.tar flash:
The extracted files to Flash include
dom.js
normal_user.js
ephone_admin.html
telephony_service.html
xml-test.html
admin_user.js
normal_user.html
xml.template
Also on the router you need to have configured:
router#conf t
router(config)#telephony-service
router(config-telephony)web admin system name [name] password [password]
also
ip http server
ip http server flash:
From there you just browse to
http://cme ip address/ccme.html
or if you have CUE
http://service-Engine ip address/
Hope that helped
Overall Rating: 5 (3 ratings)
Correct Answer
Kenneth Mohammed Fri, 06/06/2008 - 07:13
Step 1
Step 2
Step 3
dom.js
normal_user.js
ephone_admin.html
xml-test.html
admin_user.js
normal_user.html
xml.template
router#conf t
also
ip http server
or if you have CUE
Hope that helped
Kenneth Mohammed Fri, 06/06/2008 - 07:52
thanks for the nice rating!
if you do a "show flash", look and see if you have the cme-gui-x.x.x.tar file, or any of the above mentioned files already there.
Alejandro Corte... Fri, 06/06/2008 - 08:00
can you help me with this:
I have a 2801 router with cme and a four ports FXO card, I have a 800 toll free with three lines, any idea on how to configure this type of service?
Is just one telephone number asocciate with 3 physical lines on three port int he cisco fxo card.
Kenneth Mohammed Fri, 06/06/2008 - 08:16
If the 800 number is ported to your three FXO lines then there is no special configuration you need to do on the voice ports because when the 800 number is dialed, it will translate to the FXO numbers before it even hits your gateway..
