lpezj Fri, 06/06/2008 - 07:22
  • Gold, 750 points or more
You can download the CRS Script Editor easily from the AppAdmin administration webpage od UCCX. (Tools -> Plugins)
Hope this helps,
Juan Luis
kingsleyn Fri, 06/06/2008 - 07:31
Thanks alot for your response.
This AppAdmin webpage, is it on the CRS server?
lpezj Fri, 06/06/2008 - 07:38
Yes. It is the administration web page of UCCX. You can access in the way http://<>/AppAdmin
Ypu will need a user and password to access to it.
Hope this helps,
Juan Luis
(Please, don't forget to rate helpful posts ;-))
Abdulbaseer Mohammed Sat, 06/07/2008 - 23:31
  • Silver, 250 points or more
Also when you get logged into CRS admin you need to go to tools and download that editor. You also find other related apps as well same spot.
Good luck
Baseer.
ra_jeshkalra_2 Thu, 04/01/2010 - 20:47
Is it also possible to download this from Cisco Web site or somewhere else?
david.macias Fri, 04/02/2010 - 04:04
  • Blue, 1500 points or more
No, only through the CRS server.
david
dave.yeskey Fri, 04/02/2010 - 08:01
Also, you need network connectivity to the UCCX server the first time you launch the Editor.  After that you can run in standalone mode.
adrien.hemard Wed, 10/20/2010 - 04:49
If I need to make some scripts on unity express, I might use CRS editor application but it is not avaible on the module. Is that possible to get this application on CCO download zone?
thanks for your help
Adrien
