TAPS with CM 4.3
Jun 6th, 2008
Has anyone tried loading IPCCX 6 coresident with CM 4.3 and used it for TAPS? I've heard (both from Tac) that you can load IPCCX 6 coresident & that no, you can't load it coresident. The only thing we're looking to use it for is TAPs.
thisisshanky Fri, 06/06/2008 - 07:46
This is correct. IPCC 6 cannot be loaded coresident. You d need a separate server for install IPCC 6
j.dyer Fri, 06/06/2008 - 08:15
can you point me to the documentation that lays out that it can't be coresident?
The main reason i'm asking is that the install guide has "Single Server Deployment" as one of the options -- but i've heard totally different things from TAC depending on who has been asked.
I'll probably end up trying it in a lab to see what happens, but if there's documentation that says "you can't do it" -- then i can use that for justifying the extra server, or trying to get cisco to replace the ipccx 6 disks with ipccx 4.1, which can be loaded cores with callmanager 4.3
