CCM 6.1 error
Answered Question
Jun 6th, 2008
Hi. I have CCM 6.1 and after reboot i don't can open page http://ccm. On command "utils diagnose test" i see next result "est - tomcat: Error: tomcat keystore corrupted Please use remote account to login and do
"/root/.security/tomcat gen_tomcat_selfsigned.sh"
You can help me fix it?
Correct Answer by Michael Owuor about 8 years 8 months ago
Slava,
Feel free to contact TAC to have them perform the diagnosis and correction of the problem via the remote account. The appliance model of CUCM means that all of us non-TAC folks a level of access that does not provide root access.
Michael.
Correct Answer by Jaime Valencia about 8 years 8 months ago
have you done as instructed by the error???
CSCsi51295
CM 5.1 - Tomcat web certificate regeneration fails
CSCsm44886
Install fails with comma in a cert field, causes Security config failure
javalenc
if this helps, please rate
Overall Rating: 4 (2 ratings)
Correct Answer
Jaime Valencia Fri, 06/06/2008 - 09:39
CSCsi51295
CSCsm44886
javalenc
sun_sazanov Fri, 06/06/2008 - 11:15
Thank's.
Sorry i don't know, how i can use remote account. You can say me it?
Correct Answer
Michael Owuor Fri, 06/06/2008 - 11:36
Slava,
Michael.
