ASA 5520 SIP re-writing
Jun 6th, 2008
Hello everyone,
I have MAC clients trying to use iChat AV. iChat uses SIP to setup the AV on UDP ports 16384 - 16403. The ASA5520 is running 7.2(4) software and has 4 security zones. However, only 2 zones have iChat clients that need to talk between them. One zone is security level 60 and the other is level 85. If the client initiates from the level 85 zone, iChat connects every time. If the client on level 60 trys to initiate, the audio video fails. Now, a similar thing happened on with a router. I used the command "no ip nat service sip udp port 5060" to disable sip re-writing with NAT. This works great and iChat now connect every time in the router only environment. However, in this scenario, the ASA is not performing NAT, but from iChat debugs it appears that iChat still thinks that NAT is occuring. Is there a similar service on the ASA that re-writes SIP packets? Also, I was reading in Depth about application inspection maps. Could application inspection maps cause SIP failures? My rulesets allow SIP and udp ports 16384-16403 on both the 85 security interface and 60 security interface. Is there anything else I should look into? Thanks!
