Unattended CUCM 6.1 Installations
Jun 6th, 2008
I have created the answer files and saved them in their own directories each named the same "platformConfig.xml". Going thru the installation routine, the expected screen indicating that now is when the USB key with the platform configs is doesn't seem to be retrieving the files on the USB key.
I have verified that my key is bootable - I used a minimized Red Hat distro - but I can't get the CUCM 6.1 installation process to recogize or trigger the use of the USB key.
Any pointers are welcome.
bwilmoth Thu, 06/12/2008 - 07:30
  • Silver, 250 points or more
You are hitting with a bug: kindly check the details of this bug:CSCsh68282
