Unable to Lauch SDM
Jun 6th, 2008
I have installed the SDM and the SDM demo software to test using the SDM. I followed the SDM demo instructions, to use 127.0.0.1 as the loop-back IP so as to use the demo. But I get the message "Unable to Launch SDM".
One error suggestion is the wrong IP is used, the other states that HTTP or HTTPS services are not running. Now I am using XP Home, do I need to install an HTTP service to use the SDM demo on my computer?
Overall Rating: 3 (1 ratings)
Justin Brenton Sat, 06/07/2008 - 13:29
Hi chauge049,
You are correct, you do need HTTP server installed on your pc.
If your using Windows then you can using IIS.
Hope this helps, Please rate
Justin
chauge049 Sat, 06/07/2008 - 16:43
Justin ~
Thanks for your response, I thought so, however, as I only have Windows XP Home, it does not come with IIS. I checked for another HTTP server that comes with Home, but did not find one. ** Sigh** Guess I'll have to check the shareware route.
Thanks again,
Chuck
