vpn client behind asa ok to pix but not to asa
Answered Question
Jun 6th, 2008
Hi all,
I have been struggling with a couple of newly installed asa5505. We can use the vpnclient into the appliances, but not from behind another asa. Behind the very same asa we can vpn to previous pix installations. But when we go to other asa installs, we get regular translation creation failed for protocol 50.
We have enabled, isakmp, nat-traversal, udp 4500 and udp 10000. Could it be that the fault is in the other end even if the error shows in this end?
Anyone willing to help me with this?
cheers / Peter
Overall Rating: 5 (1 ratings)
Farrukh Haroon Sat, 06/07/2008 - 12:44
  • Red, 2250 points or more
Perhaps you have 'nat-control' enabled and are not exempting the VPN taffic from NAT? (nat 0 access-list)
If you post sanitized configs/more information about the topology, it would help more.
Farrukh
workorderps Sat, 06/07/2008 - 22:46
No, the problem is not to connect to the other ASA, but to use resources behind it. I can go through the ASA to PIX, and we can use resources behind the ASA if we do not pass through an ASA before. Somehow I believe the UDP encapsulation is different with the ASA tunnel as opposed to the PIX tunnel. Below is the script we run on all ASA devices, and something is not perfect yet.
configure factory-default 192.168.20.1 255.255.255.0
! appliance restarts here
domain-name mydomain.local
dhcpd auto_config outside interface inside
hostname fw
http 192.168.0.0 255.255.0.0 inside
logging enable
logging asdm informational
access-list outside_access_in extended permit icmp any 192.168.0.0 255.255.0.0 echo-reply
access-list outside_access_in extended permit icmp any any source-quench
access-list outside_access_in extended permit icmp any any unreachable
access-list outside_access_in extended permit icmp any any time-exceeded
access-list outside_access_in extended permit icmp any interface outside
access-list outside_access_in extended permit udp any any eq isakmp
access-list outside_access_in extended permit udp any any eq 4500
access-group outside_access_in in interface outside
! Crypto settings for VPN-Clients
crypto isakmp enable outside
access-list inside_nat0_outbound line 1 extended permit ip 0.0.0.0 0.0.0.0 192.168.0.0 255.255.255.0
ip local pool vpnclients 192.168.0.10-192.168.0.19 mask 255.255.255.0
group-policy MyPolicyGroup internal
group-policy MyPolicyGroup attributes
vpn-tunnel-protocol IPSec
dns-server value 192.168.20.2
default-domain value mydomain.local
configure terminal
tunnel-group MyPolicyGroup type ipsec-ra
tunnel-group MyPolicyGroup general-attributes
default-group-policy MyPolicyGroup
address-pool vpnclients
tunnel-group MyPolicyGroup ipsec-attributes
pre-shared-key MyPassword
crypto isakmp policy 10 authen pre-share
crypto isakmp policy 10 encrypt 3des
crypto isakmp policy 10 hash md5
crypto isakmp policy 10 group 2
crypto isakmp policy 10 lifetime 86400
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 set pfs group2
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
nat (inside) 0 access-list inside_nat0_outbound tcp 0 0 udp 0
! VPN Users below
username MyUserName password MyPassword
username MyUserName attributes
vpn-group-policy MyPolicyGroup
! Make config permanent.
write mem
reload noconfirm
Correct Answer
You are not allowing protocol 50 - ESP thru the firewall. The remote end VPN's are trying to create a VPN in "Main" mode not "Aggressive" mode like the VPN clients.
Add the below and test again:-
access-list outside_access_in line 6 extended permit esp any any
HTH.
workorderps Sun, 06/08/2008 - 01:58
Thank you - thank you!, that did the trick.
Maybe you can also solve my local lan access?
With the above config, using the Cisco VPN-client, set allow local lan access, but the local lan vanishes. This is due to that the local routing table gets a new default gateway, namely the dynamicly VPN IP assigned. But over the years, I've never managed to solve this.
Below is the routing table before and after establishing the Client VPN connection (it's in swedish) - but you'll see that the rout for the local lan (192.168.1.0) is routed to the VPN IP, but shouldn't it be left alone to the normal default?
Routes before VPN:
Nätverksadress Nätmask Gateway-adress Gränssnitt Mått
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.179 25
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
192.168.1.0 255.255.255.0 192.168.1.179 192.168.1.179 25
192.168.1.179 255.255.255.255 127.0.0.1 127.0.0.1 25
192.168.1.255 255.255.255.255 192.168.1.179 192.168.1.179 25
224.0.0.0 240.0.0.0 192.168.1.179 192.168.1.179 25
255.255.255.255 255.255.255.255 192.168.1.179 3 1
255.255.255.255 255.255.255.255 192.168.1.179 192.168.1.179 1
255.255.255.255 255.255.255.255 192.168.1.179 10005 1
Standard-gateway: 192.168.1.1
Routes with VPN:
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.1 1
192.168.0.0 255.255.255.0 192.168.0.1 192.168.0.1 25
192.168.0.1 255.255.255.255 127.0.0.1 127.0.0.1 25
192.168.0.255 255.255.255.255 192.168.0.1 192.168.0.1 25
192.168.1.0 255.255.255.0 192.168.0.1 192.168.0.1 25
192.168.1.1 255.255.255.255 192.168.1.179 192.168.1.179 1
217.209.119.167 255.255.255.255 192.168.1.1 192.168.1.179 1
224.0.0.0 240.0.0.0 192.168.0.1 192.168.0.1 25
255.255.255.255 255.255.255.255 192.168.0.1 10005 1
255.255.255.255 255.255.255.255 192.168.0.1 3 1
255.255.255.255 255.255.255.255 192.168.0.1 192.168.0.1 1
Standard-gateway: 192.168.0.1
OK add the below access list - you can change the name if you want to:-
access-list local_LAN_access standard permit host 0.0.0.0
And in the Group policy attributes for the remove VPN add:-
split-tunnel-policy excludespecified
split-tunnel-network-list value local_LAN_access
So the config would look something like:-
HTH.
workorderps Sun, 06/08/2008 - 03:02
Hmmm, I've had troubles with split tunnel ACLs before, but then mainly when combining Client VPN and fixed site-to-site VPN-tunnels. This was some years ago, and as far as I remember, they needed separate ACLs for it to work.
But what you say, is that the remote ASA needs to have a split tunnel configured for the vpn-client to set the proper local routes.
In any case, I have to test this when I'm much closer to one of the remote ASAs (which is tomorrow).
Thanks for your help so far, I'll report back when I have something to report.
cheers / Peter
