Tommer Catlin Fri, 06/06/2008 - 13:03
Can you post an example?
External Number 408.555.1212 is called 408.333.4444
Rings internal phone x4444
Caller ID shows 408.555.1212 on x4444's display.
metalium2007 Fri, 06/06/2008 - 13:06
ok that's the point:
-> instead of 408.555.1212 on display, i want it to show (just for this number by example) "XPTO Corp."
is it possible?
Thanks!
Met.
stafford.slater Tue, 09/23/2008 - 08:09
Hi Met,
Did you get anywhere with this? I have a TCL script that can handle this with a H.323 gateway but would be great to do it with MGCP gateway.
Cheers,
Stafford
