Need data to be presented via the agent desktop
Jun 6th, 2008
I need to present the following data via the agent desktop and would like to know how this can be done:
Time in queue
Menu selection/choices
Calling party number
joergwesely Fri, 06/06/2008 - 14:31
You can use the "Set enterprise parameters" step in the CRS Editor to put Data in the agent desktop.
sementellic Sat, 06/07/2008 - 05:51
Thank you for your response...can you send me more descriptive detail of what you mean? I am new to UCCX and scripting so I may need some guidence. thank you.
sementellic Sat, 06/07/2008 - 05:50
thanks for your response....its UCCX 5.0 and I am using CAD
daljeetsingh1_2 Sun, 06/08/2008 - 05:52
As stated in the below email, you can use "set enterprise call info".
I am pasting one sample call flow to pop up customer name, you need to tweek it as per your requirement. And there is a doc on cco, which will also be of little help.
All the best & Hope it will be helpfull
Thanks, DJ
GeorgeHohlov Sun, 06/08/2008 - 10:33
I have the same need, but I use UCCE, CTIOS Agent Desktop. In the Routing Script I make node «Set callPeripheralVar1 = CallTimeInQueue», but in the agent this variable is always 0.
