CUE Editor
Answered Question
Jun 6th, 2008
I am trying to use the CUE editor to create a customer script for an auto attendant. I can install the program with no problem. However, when I run the program a quick box flashes up on the screen and then goes away with no indication that the program is running. I believe the problem is with something that our IT group is keeping my laptop from running as this problem happens on my other co-workers machines also.
Any idea what can be keeping this application from running would be great so I can direct my help desk as to what to change.
Seth
Correct Answer by Rob Huffman about 9 years 1 month ago
Overall Rating: 5 (2 ratings)
Markus Schneider Fri, 06/06/2008 - 18:01
  • Cisco Employee,
What OS are you using? For vista (which isn't officially supported), you should try the following:
- right click on the CUE editor icon
- Select the Properties option - a new window opens up
- Select the Compatibility Tab
- Check box 'Run this program in compatibility mode for Windows XP
- Check the box 'Run as Administrator'
It might also be related to the MSJVM version, but I'd try the above first.
srosenthal Fri, 06/06/2008 - 18:37
I am running Win XP SP2. They removed the Microsoft JVM from our machines, would that be the cause? Can it not work with Sun Java?
Correct Answer
Rob Huffman Fri, 06/06/2008 - 18:58
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
srosenthal Sun, 06/08/2008 - 11:23
I uninstalled both the CUE editor and all JAVA versions on my computer. Then re-installed CUE Editor and it then installed Microsoft VM and then I installed JAVA and it works. I have to yell at our help desk and tell them to stop removing MVM.
Thanx again.
Rob Huffman Mon, 06/09/2008 - 04:38
  • Hall of Fame,
    Founding Member
Hey Seth,
#!%##! desktop support (hahaha) Our group was thinking of switching to Vista recently, I just kept visualizing those crazy Mac commercials ;-)
Take care,
Rob
