Dual ISP with PfR Config
Jun 6th, 2008
Thanks for the help with this, its new territory for me. We have two bonded T1's from one ISP currently. We would like to add two more T1's from another ISP for load balancing and for failover purposes.
Can I use two of the Two Port T1 WICS in a 2811 router to connect the four T1 lines? That will provide me with two additional slots for future expansion, if needed. Can the 2811 handle a full 6Mbps throughput?
Also, assuming the above configuration works, I would like to implement the new Performance Routing, PfR to improve bandwidth usage. Thanks again for any help.
Paolo Bevilacqua Fri, 06/06/2008 - 12:54
Yes, you can connect the additional circuits to any interface you like. 6 mbps is ok for a 2811 and in fact you could use a smaller router as well. PfR is not a cisco term so you need to clarify on that.
