3640 MLPPP accross 2 NMs
Jun 6th, 2008
Can a 3640 do MLPPP across multiple NMs? My customer wants to up his Internet from 3, to 6MB. I need to know if the 3640 will allow MLPPP accross 2 NM slots. Thanks.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Fri, 06/06/2008 - 12:52
Yes, there is no limitation about to which card the interface belongs.
d508971 Fri, 06/06/2008 - 13:30
Thanks so much for your quick reply. The question now is will the WIC-1DSU-T1-V2 work with the 3640, since the WIC-1DSU-T1 is not for sale by Cisco anymore
Paolo Bevilacqua Fri, 06/06/2008 - 13:38
Yes, as mentioned above, you can mix an match as you wish.
As a recognition tho those prividin answers, please rate useful posts with the scrollbox below!
