Redundant interface pairs like ASA on routers?
Jun 6th, 2008
I'm designing and configuring a new network and I would like to connect one router with two interfaces to the same spanning tree domain (a couple of switches). A third interface is going to another subnet.
I would like to have the two interfaces to be redundant and provide subsecond failover. So a BVI with spanning tree on the router is not really an option.
Is it possible to configure redundant interface pairs like ASA 8.0 on a router? Or is there another way to accomplish this?
Overall Rating: 2.5 (2 ratings)
cowetacoit Fri, 06/06/2008 - 12:50
So two router interfaces connected to the same switch? or each router interface connected to a different switch?
2044418Puts Sat, 06/07/2008 - 07:06
The two interfaces are connected to different switches, but connected to the same layer 2 domain / vlan / spanningtree domain.
andrew.butterworth Sat, 06/07/2008 - 08:03
You could do it with bridging on the router:
bridge 1 protocol ieee
bridge irb
interface FastEthernet0/1
bridge-group 1
interface FastEthernet0/2
bridge-group 1
interface BVI 1
ip address
2044418Puts Sat, 06/07/2008 - 08:19
Yes this is an option, but I would like to have subsecond failover between the links.
Is it possible to configure uplink fast between these links?
andrew.butterworth Sat, 06/07/2008 - 08:38
You could tune STP to try and achieve these kinds of times, however I think you want to be looking at alternative designs.
Dual routers running HSRP/GLBP is where I would be looking.
