06-06-2008 12:45 PM
We are trying to load balance 2 backend servers hosted on Websphere with advance balance cookies method.
Restrictions
ServerA is unable to accept cookies generated from ServerB.
ServerA and ServerB are generating random cookies
Unable to modify cookie string with a constant.
How can we load balance based on cookies considering the above restrictions?
We have attempted to do hash based load balancing with cookies but the problem we run into is the servers do not accept cookies generated from another server.
The configuration we tried is written below:
service ServerA
ip address 192.168.10.2
keepalive type tcp
keepalive port 80
active
service ServerB
ip address 192.168.20.2
keepalive type tcp
keepalive port 80
active
content ABC
url "/*"
add service ServerA
string prefix "JSESSIONID="
advanced-balance cookies
port 80
add service ServerB
string skip-length 5
string process-length 16
string operation hash-xor
protocol tcp
vip address 172.16.32.1
active
Can we change the string prefix to JSESSION instead of JSESSIONID= ?
The only place the app guys can add a constant string to match on is before the = sign.
Is it possible for CSS to match on a constant string before = sign e.g below:
service ServerA
keepalive type tcp
keepalive port 80
string id567=
active
service ServerB
keepalive type tcp
keepalive port 80
string id123=
active
content ABC
url "/*"
add service ServerA
string prefix "JSESSION"
port 80
add service ServerB
string skip-length 0
string process-length 6
protocol tcp
active
Solved! Go to Solution.
06-07-2008 07:21 PM
go for arrowpoint cookies.
The CSS will generate its own cookie.
Much easier.
No need to modify the servers.
the command you need is 'advanced-balance arropwoint'.
Gilles
06-07-2008 07:21 PM
Much easier.
Gilles
06-07-2008 08:37 PM
Gilles,
We have tried using the arrowpoint cookies method as well but it did not work for us.Infact the configuration was provided to us by a Cisco TAC engineer and while we tested it, he was on Webex session.
Thnks,
Dev
06-08-2008 04:10 PM
It should work.
There is no reason for it not to work...
This is the best method you can have on the CSS for stickyness.
Get a sniffer trace on the client and server with arrowpoint cookie configured on the CSS and capture a failure so we can see what is going on.
also send me the config so I can verify everything is ok.
If you have a service request open with the TAC, you can also give the SR # so I can review what has been done.
Gilles.
06-16-2008 02:17 PM
Gilles,
We tried the arrowpoint cookie once more and after taking some sniffer traces, we found out that the client app was not passing the arrowpoint cookie back to CSS, so the CSS was following the regular round robin load balancing.App guy had to modify the code to recognize and pass the aarowpoint cookie back to CSS.Well for now everything works fine. Thanks for the help.
Dev
