BCMSN simulation questions
Jun 6th, 2008
Hi! I'm getting ready to take BCMSN exam.
What kind of simulation questions should I expect? I bought transcender virtual labs to practice different configs. But there are only 5 labs, and I worry that they don't cover enough material for the exam.
here is the description of the labs:
http://www.transcender.com/gen.aspx?sn=TRACert-642-812_t-vlabCourse_desc&pf=page
JORGE RODRIGUEZ Mon, 06/09/2008 - 20:45
Irina,
First you need to look at the BCMSN exam Syllabus which will described what is expected from the exam taker to be proficient on to successfully pass the exam, look carefully at each of the components required and compare it with the transcender virtual labs materials given to determined if indeed they cover the exam requirements, you may need a combination of lab simulation in addition to thorough reading and undertanding of the materials.
642-812 Syllabus
http://www.cisco.com/web/learning/le3/current_exams/642-812.html
If you feel the transcender materials does not cover the above requirements you may need to look into other materials to practice on, personally I never used transcender in the past but heard good reviews.
You may find on this lin some useful e-Lab-simulations and interactive exercises, these are free from cisco.
http://www.cisco.com/web/learning/le31/le46/products/products-switches.html
Good luck
Rgds
-Jorge
ipmask2007 Tue, 06/10/2008 - 10:32
Jorge,
Thanks for your reply.
I looked at the switches link you provided. But I couldn't find any lab simulations. Can you tell me more specific which simulations you are talking about, and which ones you think are good
to try for the BCMSN exam?
