Problem with ACS 4.1 using certificate
Jun 6th, 2008
I have an ACS 4.1 appliance, I have already configured ACS in order to work with certificate. I got the certificate from ACS, I already installed it as the installation guide says . Additionally I configured the card's controller in my PC in order to manage certificate.
Whe I try to be validated from ACS I can not go on because a message appears and says " click to select a certificate " , after click a windows appears asking user and password however I expected not receive this window.
The switch's port were configured as follows:
aaa new-model
aaa authentication dot1x default group radius+
dot1x system-auth-control
interface GigabitEthernet1/0/4
switchport mode access
dot1x mac-auth-bypass eap
dot1x pae authenticator
dot1x port-control auto
dot1x timeout quiet-period 15
dot1x timeout tx-period 3
dot1x reauthentication
radius-server host (ip address) auth-port 1645 acct-port 1646
radius-server source-ports 1645-1646
radius-server key password
What am I doing wrong or there is something left???
Farrukh Haroon Fri, 06/06/2008 - 17:49
  • Red, 2250 points or more
1) Did you install the Certificate file in the local machine? (Right click >> Install Certificate >> And so on..)
2) Are you using the built-in Dot1x supplication in WIndows XP? Is the setting to MD5?
3) Did you Selected this installed certificate from the drop-down Menu in the wireless software?
Farrukh
