Max no of extensions for UC500
Jun 6th, 2008
I would like to know what is the maximum number of ip phone extensions that can be supported by the UC500, i have the 24user model.
From my understanding; my 24 user model, is capable to support up to MAX 24 IP PHONES. How about the number of extensions?
I am using the IP Phone 7945g, that supports 2 line keys.
Is the maximum extensions dependent on the number of line keys on an ip phone?
Plz advice
Rajesh Revuru Sat, 06/07/2008 - 00:03
  • Silver, 250 points or more
Did you try this entering the following command under telephony-service
max-dn ?
It will display maximum number of dn your system can support
techiegzz Thu, 08/12/2010 - 03:58
What is the maximum number of digits the extensions can have?
paolo bevilacqua Thu, 08/12/2010 - 08:26
  • Hall of Fame,
    Founding Member
There is no limit. Common sense recommend a maximum of 4.
brendand05 Thu, 08/12/2010 - 21:20
A show ver will tell you how many user license you get.
The 24 user model gives you 28 or 30 licenses
Under telephony-service run
'max-ephone ?'
'max-dn ?'
To see the max # or ephones or DNs
You should use either 3 , 4 or 5 digit extensions depending on the size of your office and existing dialplan
