Get a dump from CUCM 6.0(1)
Jun 7th, 2008
I have an issue: one-way hearing due to my CUCM is under NAT/FW with its IP Phones.
I always use Wireshark (aka Ethereal) program's capture method to troubleshoot
such a problems; you know, to see what is going on on the wire. Is there any
method to get the network dump on CUCM Linux appliance and have possibility
to analyze it through 3d party software (e.g. Ethereal) later ?
If yes, please, advice how this can be performed ?
If no, what is the best methodology to see how the
CUCM and IP Phone negotiate the signaling and voice connections.
I've been looking through RTMT tool but cannot find anything relevant.
Overall Rating: 5 (1 ratings)
Justin Brenton Sat, 06/07/2008 - 12:47
  • Silver, 250 points or more
Hi Tobivan,
The first thing you should check is the firmware that your phones are using. There maybe some known issue's with that version.
Is QOS currently in place? Are you using CEF (Cisco Express Forwarding)?
Any additional information about your network would help as well.
Please also review the following document as this should get you started.
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a008009484b.shtml
Hope this helps,
Please rate,
Justin
Tobivan_Helden_2 Mon, 06/09/2008 - 02:11
Justin,
Thank you for your recommendations.
But before I will start investigation in according with them,
I want to be sure that the shcheme
SCCP-based IP Phone #1 CUCM <> SCCP-based IP Phone #2 (within the same subnet as CUCM)
is operable in principle. Currently I have one-way hearing.
Jaime,
Thanks so much.
