Translation numbers for ephones
Answered Question
Hi! I have a 2811 router with UCM 4.0 2811 connected to ISP by E1.
[PSTN]----e1----[2811]--ephone
I want to do translation of incoming numbers, going to ephone (for example, translate incoming calling number). I know about voip-incoming translation, but it works only with h323, I know translation in dial-peer, but it don't work for ephones. How can I do translation numbers for ephones?
Correct Answer by paolo bevilacqua about 9 years 3 weeks ago
That is the "rule 100" I made an example above. You complete the config with:
voice translation-profile add9
translate calling 100
voice-port 0/x/y:15
translation-profile incoming add9
Note in many countries no external access digit, like 9, is needed.
For example when "2" is not used by your country dialplan, make all extensions begin with 2 and it will be like calling from home, users like that very much.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Sat, 06/07/2008 - 04:05
  • Hall of Fame,
    Founding Member
Are you using MGCP or H.323 with the CM ? If the first case, you need to do all translations in the CM.
paolo bevilacqua Sat, 06/07/2008 - 04:21
  • Hall of Fame,
    Founding Member
Actually it's simpler with CME. Here we call it CME, and CM the big one.
To translate called number on incoming, and calling on outgoing, there is a single command to do that:
telephony-service
dialplan-pattern 1 6111222.. extension-length 3 extension-pattern 2..
Other type of translations require voice translation-profile and rule. Typically if you're using a prefix digit to dial outside you will add that in front of calling number, and something the double 0 for international:
voice translation-rule 100
rule 1 // /9/ type national national
rule 2 // /900/ type internaitonal international/
Correct Answer
paolo bevilacqua Sat, 06/07/2008 - 04:34
  • Hall of Fame,
    Founding Member
voice-port 0/x/y:15
