which switch cheaper than 3560 switch?
Answered Question
Jun 7th, 2008
i ask silly question.but to save time i ask it.i want cisco switch cheaper than 3560 switch.I need POE and 10/100/1000 speed must.ok? pls reply.regards.
Correct Answer by Jon Marshall about 8 years 11 months ago
Sushil
Good spot, i missed that one. Rated. The 2960G switches do support 10/100/1000 but not PoE.
Abdul - apologies for the misleading information.
Jon
Correct Answer by Sushil Kumar Katre about 8 years 11 months ago
Abdul,
Unfortunately this is the only switch which can give you PoE on 10/100/1000 interface.
There is a 2960 switch which supports PoE but on 10/100 interfaces.
So I guess no other option.
-> Sushil
Overall Rating: 4.3 (5 ratings)
Jon Marshall Sat, 06/07/2008 - 09:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The 2960 switches are probably what you want to be looking at. You don't say how many ports you need but assuming 24 or 48 there are 2 models that support 10/100/1000 + PoE
2960G-24TC-L - 24 port 10/100/1000 + PoE for all 24 ports.
2960G-48TC-L - 48 port 10/100/1000 + PoE for 24 ports only.
See this link for more details:
http://www.cisco.com/en/US/products/ps6406/prod_models_comparison.html
Be aware though that the 2960 switches are layer 2 only switches so they will not support inter-vlan routing. For a L3 switch you have to start at 3560.
Jon
Sushil Kumar Katre Sat, 06/07/2008 - 09:29
  • Gold, 750 points or more
Hi JOn,
I guess, 2960 TC-L model does not supports PoE + its not Gig based interface. It providse FE interfaces.
Cisco Catalyst 2960-24TC-L
24 Ethernet 10/100 ports and 2 dual-purpose uplink ports
Cisco Catalyst 2960-48TC-L
48 Ethernet 10/100 ports and 2 dual-purpose uplink ports
The PC-L switch provides PoE interfaces bu tagain its no GE but FE interfaces -
Cisco Catalyst 2960-24PC-L
24 Ethernet 10/100 PoE ports and 2 dual-purpose uplink ports
And there is no 48 port PoE model.
-> Sushil
Correct Answer
Jon Marshall Sun, 06/08/2008 - 00:55
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Sushil
Jon
Sushil Kumar Katre Sun, 06/08/2008 - 04:13
Hey Jon,
No Problems. This is the beauty of this forum. Ultimately the correct information goes to the user. We all keep making slips here and there :)
Being a human being I guess we should have that much liberty.
-> Sushil
contact_abdul Sun, 06/08/2008 - 04:45
thnx Jon,
Now i will take some points from sushil and give to u.kidding. regards. thnx all buddy.
contact_abdul Sat, 06/07/2008 - 14:01
thnx Jon. I needed 24 ports and 10/100/1000 and poe.
guys is there any others than cisco brand which is having same features and still cheaper than cisco? I guess i ought not discuss other than cisco here :)
regards
abdul
Correct Answer
Sushil Kumar Katre Sat, 06/07/2008 - 09:25
Abdul,
-> Sushil
contact_abdul Sat, 06/07/2008 - 13:58
Thanks to sushil and JON and others for timely response.
sushil i gave u full points :) regards.I love this forum .
engr. abdul
