Debug Output
Jun 7th, 2008
I am using debug ip packet command with ACL on 7600 router but no output seen.
Is debug command with acl has issue?
Farrukh Haroon Sun, 06/08/2008 - 04:16
Are you telnetting into the router?
If so don't forget the 'terminal monitor' command.
Also 'logging monitor 7' should be configured.
If you connected through the console, 'logging console 7' should be there.
Also are other debugs working/displaying?
Farrukh
